Check Engine Light is on...
did you disconnect anything electrical while ignition was on as that will throw a error code and the fault light will come on, if you did disconnect the battery for about half an hour and reconnect that should clear it if the light comes back on later then there is something needing attention
Go with the black I MO.you could call in to my home in waikiki if you are going by and we could have a look with my puta
Thanks Peter, turns my original plan of ignoring it worked just fine. Went off after about 2mins on the way home. Gear Indicator started working again too.
It's cleared now...she sat outside in the rain all day Monday and this morning was the first time I'd started it since
