cootertwo
- Joined
- Mar 24, 2013
- Messages
- 2,126
- Location
- Labelle Florida USA
- Ride
- 2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
Well, I found my second water leak last evening. A 3/4" coupling had come loose under ground, on a run from the house to the barn. Now, after I finish my coffee, might go tinker with the Rocket. Going to switch back the CPS to the one that measures 570 ohms, instead of the one from the 2015, that measures 1.2K ??? And probably pull the fuel rail and make the injectors squirt, pull 3 plugs, check compression, and spark. Vacuum hose good, including the "Cross" fitting.
