Lester532
Turbocharged
Hey everyone, even though the Dyno Beads are extremely small in diameter, they won't pass through the valve stems on the Rocket. Apparently the 90 degree style of the stems has an "even smaller" diameter air passage and the beads will not make the turn. They will work on standard valve stems (so the instructions say). Be sure to get the beads and weigh them out (weight chart per tire size on-line) before having the tire mounted so the installer has them to put in before inflation. I provided my installer with a small funnel and about 12 inches of tubing slipped on to allow the beads to be poured into the tire as it lay on the mounting machine (horizontal).
Just a little FYI.
See ya.
They fit through the valve stems on my Rocket. You do have to remove the core but I thought that was obvious.
