Car Wash for R3s ??????
RocketFuture
Walla Walla, WA USA
2008 R3 Classic, 2004 1100 Yamaha Classic
I'm the proud new owner of a 2008 R3 Classic and I'm wondering if it is safe to wash it at a manual car wash with the soap and high pressure car wand? My 2004 Yamaha 1100 does fine with it but I have heard you can't do that with a Harley or you will get water into engine or components. How about the R3 car wash or no?
Thanks!!!!
Pressure washers on any bike are a bit of a problem. There are so many parts that water under pressure can get into that can cause problems.
Just laziness and you won't find that loose part that's about to fall off while pressure cleaning.
i have done min with the pressure washer a couple of times with no side affects but i tend to be careful around the gauges,ign switch and don't spray it up the exhaust
if you have after market air filters i would not wash with pressure.
Yikes!!! is sounds like I may have to pull out the old bucket and soap!!!! ( I'm on well water so I better do a little test on it to make sure it doesn't have too much minerals in it I couldn't stand to get hard water spots on my baby!!!
I use regular car wash and wax on my R3T and just a garden hose. I would not pressure wash. I cover my handlebar controls with some plastic bags from the store and make a point to not to hose a lot of water under the tank. A fine mist works best for a rinse. They also recommend you cover the exhausts but I don't spray a lot of water around my pipes anyway. After washing, I use an electric leaf blower to blow off most of the water from the surfaces. A final wipe down to finish it off and your done. I also use aluminum wheel spray, some Meguire's Motorcycle Spray and Wash, back wash my radiator to get the bugs out and a variety of other things as needed.
Is your bike THAT dirty?
If you must use a car wash dont use the high pressure - use the final rinse water to hose down as this water is usually cleaned through reverse osmosis snd wont leave water marks when dried.
Bottled spring waters what I use .... .... no I don't
I pressure washed mine in Torquay last RDU , I kept the nozzle at least 1.5-2 metres away and didn't use full pressure , I wouldn't use one if I had alternate means to wash .
