Mine only seeps (somewhere behind throttle bottles) when you run hard in high RPMs. Take it easy and she stays dry. Not much, only a very slight trickle down left rear side of engine which wipes off with paper towel. Not worth replacing yet.
That is exactly where my leak is, luckily under warranty.
Depends on how hard and how long you're banging through the gears, and if you tap the brakes just a bit when needed to avoid a big get off ! Ride her slow and steady and you can stay on it for hours......but what's the fun in that? Ride hard, wind her out and hang on! Always puts a smile on your face!
I can't remember if its been discussed on here but it seems to be about the time the Roadsters came out, the cam covers no longer have the cast groove around the gasket surface. That seemed to help hold the gasket in place. My '05 still has the factory installed gasket. I just had it off this spring to check the valves. It still doesn't leak. I think the only way to fix the problem on the newer ones is to buy an early cam cover. Or possibly have a machine shop cut a groove around the one you have.
Pretty sure I have a grooved one in the shed that I will use later.
The early version Chromed cam cover is T1260229 replaced by the Chromed version on the Classic T1260387 that was released with stockpiled earlier silver engines initially after the first black engines had started to be used for Standards.
I found another part number too..T1260514 with references > Eng No 242554 Classic only.
1T1260514 | Cam Cover ChromedT1260514 Cam Cover Chromed | Genuine Triumph Motorcycle Part£150.431 Add
1T1260383 | Cam Cover BlackT1260383 Cam Cover Black | Genuine Triumph Motorcycle Part£151.361
Maybe it was the special washers? ;) 🤔:roll::roll::roll::roll:
T3555003 - T3 WASHER 12X18X1.2​
  • Reference​
    6
  • Part Number​
    T3555003
  • Description​
    T3 WASHER 12X18X1.2
  • Notes​
    > Eng No 229746
Originally on VINs before 242554, but most parts listings refer to engine number erroneously
T1260387 - T3 CAM COVER CHROMED​
  • Reference​
    1
  • Part Number​
    T1260387
  • Description​
  • Notes​
    > Eng No 242554
Later black engine ones:
T1260383 - T3 COVER CAM BLACK​
  • Reference​
    1
  • Part Number​
    T1260383
  • Description​
    T3 COVER CAM BLACK
  • Notes​
    Eng No 242555 >; not Classic
RefPart NumberDescription# On Img# Cart$ EachNotes
1T1260387T3 CAM COVER CHROMEDx1362.05> Eng No 242554
1T1260383T3 COVER CAM BLACKx1394.80Eng No 242555 >; not Classic
1T1260387T3 CAM COVER CHROMEDx1362.05Classic only
2T1260079T3 SEALCAM COVER LBx154.55
3T1260309T3 SEAL CAM COVER SCRx98.60
4T3332050(NLA) T3 BOLT LGE SKT HD SHx97.65
6T3555003T3 WASHER 12X18X1.2x92.25> Eng No 229746
  • Cam Cover
    1Cover, Cam, ChromedT1260229
    1Cam Cover, BlackT1260383
    1Cam Cover, ChromedT1260387
    2Seal, Cam CoverT1260079
    3Seal, Cam Cover, Screw, Twin LipT1260309
  • Service Kits​
    7Seal, Cam Cover, Screw, Twin LipT1260309
    8Seal, Cam CoverT1260079
I replaced my valve cover gasket on my Roadster last year. At the same time I checked my valve clearance. With that info in hand, I ordered shims and planned the job for this summer. Just completed the shim replacement and decided to reuse my VC gasket from last year. I have been using cyanoacrylate glue, dabbed in the key spots where the gasket usually moves to prevent this. Did it last year and again this year. The gasket hasn't budged.
Hey guys
For this job, do I really need to order and be ready to replace sealing rings that go under cam cover bolts
T1260309​
OR reusing them is a good practice? Do they actually seal the oil or serve as a cushion between the bolt head and the cam cover?
Hey guys
T1260309​
I'm still using the factory seal rings and gasket on my '05, and yes they do seal the oil.
