imcool
Turbocharged
- Joined
- Feb 22, 2022
- Messages
- 796
- Ride
- Rocket 3R 2022
abs bleed never works with Tune Ecu OR DEALER TOOL . CO . UK , BOTH companies/developer said to me in writing that it will never work and wont be supported.There is an option to use TuneECU to activate the ABS solenoid and a great big warning before you use it. Ideally the ABS fluid would be changed out when you do a flush and refill, however that requires activating the system electrically to open the valve. The Rocket however is an open system so there isn't a need to activate the ABS, the shop manual provides instructions for simple brake bleeding when renewing the brake fluid.
