HarveyA
- Joined
- Aug 8, 2023
- Messages
- 13
- Ride
- 2021 Rocket 3 GT
Hello fellow rocketeers
Had my GT sinse new in 21. Love the bike! Done 35k kms and has served me well.
Recently I changed the front pads, replaced all brake and clutch fluids. Simple enough, and typically got a few bubbles out of the rear. The replacement pads are not OEM. Dot 4 fluid used and it was new. After the change, I thought I'd see if tune ecu would purge the abs module, it wouldn't. Have done 700 odd kms since and all is well, however there is a humming or buzzing from what appears to be the abs module. Initially I thought it was the pads over the drilled discs, they work well, I wasn't concerned. The other day I noticed it may actually be coming from the abs module. Backing out of the garage and applying the brake it still hummed for a short period after stopping, I could repeat this.
I don't recall hearing this before, there seems to be no error light from abs. The braking seems fine. What am I hearing here? Should I be worried?
Appreciate
Appreciate
