Ugarte
Turbocharged
Finally pulled out the bevel box drain plug that I had broken a couple of years ago. I have been changing gear oil by pumping it out. It was a royal pita to get the broken plug out, wish I had looked at this thread again before I attempted it. What finally worked was jamming a flathead screwdriver I had modified into the bolt after tapping the magnet back aways. Lots of time on my back on the garage floor in 100 degree heat. I had already bought an OEM plug so I put that one in and gently gave 15 nm. Its not much force, no wonder so many break these plugs.
I also removed the rear brakes to inspect them because I could hear metal grinding when I applied the brake. The retainer bracket had come loose. What surprised me was when I took the bike for a ride it no longer has a front wheel wobble at 40 mph when I take my hands of the bars. I have had this problem for a couple of years and have retightened the front steering stem nut several times without any improvement. I was going to take it down to the dealer to see what they could do about it.
The only thing I can think of was the rear axle nut must not have been torqued tight enough and there was just enough play in the rear wheel to cause the front wheel to wobble at 40 mph.
I will admit I have guesstimated torque many times and gotten away with it, no more. Too much, too little, either way its bad juju.
