Barometric pressure sensor???
bebsy
Finicky
Pattaya Thailand
2006 Triumph R111
Afternoon all...could anyone pls tell me if i need a barometric pressure sensor to tune ecu? When i fitted the ram air all that was removed? And that was only thing i never put back and she has run just fine, off to the dyno tmrw but not so sure now put me out of my misery pls.
The barometric pressure sensor fits into the rear of the Ramair. Thre is a hole in the rear of the filter where it fits.I would think that it needs to be there or you would be showing the orange MIL light on the dash.
I believe thats tha mass air temp sensor that people are plugging into the filter. The. Barometric sensor is in the upper front corner of the air box under the seat. Since you said nothimg about a code or engine light I would take a guess as to maybe you had a triple filter set up where the air temp sensor was taken care of and installed in its own filter. If that's the case your fine.
Thanks for correcting me yet again Scott.:)
Thanks for the feedback sorry if it ruffled any feathers lol, in the exploded few in the manual it pointed to the left panel it turned out to be on the right i found out after alot of head scratching my laziness wins again...cheers.
