sirwin
Standard Bore
- Joined
- Apr 8, 2008
- Messages
- 6
Gents:
I'm preparing to tackle an install of the Audivox CCS-100 universal cruise control system on my 2009 R3T. I've read every internet posting (Triumph and non-Triumph) on the Audiovox install I could find, and of course found the RIII-related posts on this site to be the most informative. However, I do have two lingering questions that I'm hoping those of you who've already traveled the Audivox road can answer before I start tearing into it:
1. How does the ball chain (connecting the servo to the throttle bodies) actually attach to the throttle actuator under the bear claw? I've seen plenty of pics showing how the throttle control cable attaches to the bike (typically with a fabricated bracket), but no pics of how the ball chain attaches to the actuator. Other (non-Triumph sites) mention driling and tapping the actuator, etc. How is it done on the RIII actuator?
2. Is a vacuum reserve canister required, or does the installation of a check valve in the vacuum line between the throttle bodies and the servo do the trick? I've ready several posts indicating the vacuum reserve canister is not necessary, but every install instructions I've found that includes pics also includes the canister. I've also read of some folks having trouble with the cruise control holding at high speeds (presumably due to the reduction in vacuum). Can anyone with the Audiovox set up on his/her RIII provide some advice on the canister vs. check valve (or canister + check valve) issue?
Thanks in advance!
Scott
Thanks in advance!
Scott
