And another thing (R3GT/R Key Fob)...
technoguppy
Toronto, Ontario, Canada
2020 Rocket 3 GT
Any suggestions to adding a key-ring to the R3GT / R key fob?
The hole alignment makes it literally useless for any standard keychain ring.
I had two tie-wraps in mine (for redundancy) but it looks like ass!
Anyone solved this? Photos if you have them.
Thanks in advance.
Not a problem.
Now put it in your pocket.
Sure I can add a key ring and keys. That's not a problem.
The mobility of the keys and fob is limited to the point of serious interference. That's the problem that needs to be solved.
I'm not being a dick, but i don't get the problem. This is the same setup i had on my 1200 Scranbler, and i keep the keys in sleeve pocket in my jackets. I don't find it a problem using fob, fob key or the lock keys on the ring. :confused:
Use 2 rings. A small one to attach to the fob, and and another one with keys on to attach to the fob ring.
That's what I originally planned but never got around to because it worked well enough for me as to not cause any aggravation or problem.
Apologies Captains as my issue is not with your solutions...
Simply put I (like you) paid $30,000 CAD for a bike. I should be able to put the f@cking fob in ANY pocket with any combination of other things on it (USB, house key, door fob, etc..) I have considered tie wraps, small rings, large rings, dual rings, steel cables, etc... This is a real miss from Triumph among a few others... Don't get me started on the lack of Rocket 3 apparel or branded merchandise available... nada!
I appreciate the suggestions and please do respond if you've found a solution.
Thanks in advance.
Thanks in advance.
