This is on the face on the full three set of rear wheel bearings kit with an oil seal for the right side as well, packaged for ALL BALLS RACING https://www.allballsracing.com/25-1588.html. I previously paid $40 for one right side bearing with oil seal from a Triumph dealer, including $10 shipping. I then found the left side inner bearing was also froze up (2007 with 30+ k miles) This $42 package arrived in short order suprisingly included both left side bearings, I had expected only the inner left hand side, and the right side bearing with oil seal. Look for ALL BALLS Racing product. I got my set of bearing from Jawzys.com Powersports. Full 4 piece set $41.94 delivered from Jawzys, while allballsracing.com list price is 39.88. These bearing are KML bearing factory products.
Since I am going dark side and getting the splines greased up and the differential oil changed, might as well do these too. Cycle Gear is the local dealer, I'll see how fast they can get them in. Thanks.
Most decent motorcycle shops can get All Balls products. The KML bearings tend to have tighter clearances than most stock grade bearings, as do a few other brands that you can find at your local Motion Industries - if you have a part number or the bearing dimensions.
