There is..you want to lean off cylinder1 by say 1%, but enrich 2 & 3 by 1%,heres what you do:
Go into the F tables , go to F1 table & get a calculator. Manually reduce every number by TWO % ie Times by 0.98
yes this takes time.. but it works.
Once you've done that go to the trims table & add +1 to all the table.
Net result F1 is reduced by 1% ( minus 2, +1) 2 & 3 raise by 1%.
I have done this ( actually adjusted 2 of the F tables.. twice as much work, before trim averaging) & the bike ran heaps better.
If 90+% of your riding is in a narrow rev band ( ie cruising) you might only want to adjust the 2-4k revs 5-50% throttle range,( the lazy way to do it)
Next time you wanna check the results, just take the spark plugs out & compare ( way easier than headers) So long as they all look the same, then you know they're close to the balance.
