Accessory Power
Pete Dixon
Wiltshire UK
Chaps
Just bought a satnav with a Triumph power lead on it (off a Sprint ST). I understand that there are spare power source 'plugs' somewhere near the front of the bike to plug things like heated grips and foglamps into. To save me taking the front end apart when I only need to lift a cover, can anyone tell me where to look?
Thanks
Pete
Hi there at least 2 if not 3 power plug under the tank .they are triumph plugs but you can buy a short lead to fit for about £6 to save cutting the loom.... if you are not fitting triumph bits i just cut the end off and wire the ass in ,.
There are lots off people on here will tell you lots more .............
Thanks.......I'll be lifting that tank then.......just as son as I can get it emptied a bit more...
I presume they are blindingly obvious......ie sat there with nothing plugged into them?
pretty much, yes. Might have to poke around at the frount end if they're tucked out of the way tho.
I can empty mine very quickly then fill it up to get home ..............then i have go out to empty it, this goes on and on so i do not lift the tank that often..............:OnTopic:
The small harness can be acquired from any dealer..........
