After changing my rear tyre the other day the ABS light came on after 12 to 15 kms, I ended up taking the sensor disc off the rear wheel and straightening it out, put it back on, did 50km so far no ABS light.
I have not checked if there is a error code in Tune ECU.
I must have slightly bent the disc when removing or replacing the wheel, it is a pretty weak alloy disc.
It is standard for the ABS alight to stay on for a minute or two of riding after starting off.
thanks for jumping in. at a hundred that is a bargain the dealer will charge u more just to hook it up.
plus it might tell u where the prob is front or rear.
big plus the anti lock might save your a$$. literally.
