2014 R3T Foot Rests Wobbling
Tank
Hey lads;
I just noticed that my foot rest on the brake side wobbles back and forth yet the clutch lever side is stable.
Is this normal or should it also be stable on the brake side.
Cheers
Have you tried tightening up the bolts that hold it on .. if they are loose maybe no .. if they are tight perhaps yes.
It seems to be mounted with a pin and not bolted
They should not move laterally but should move a bit horizontally towards the bike
Okay so I have another minor warranty issue.
Lots of little tinkery issues with this bike thus far
1. Saddle bag lock malfunctioned and needed tightened
2. Fog lamp wasn't tightened enough and fell over while riding
3. Missing the grommet around my key ignition
4. Wobbly foot board
At least ill have a list for the dealership
Hello James, that is not normal as mine now has 10K miles on it and is still nice and tight...
Boog If you put your hand under the outside of your floorboard and pull up towards the bike does it pivot up a little?
Yes it does, but I do not sense any odd movement when riding. Did I misunderstand the issue at hand? My boards move along the hinge in a nice tight manner.
Yeah I'm not really sure what he meant,
Sorry lads let me try and clarify it. My foot rest does pull up towards the bike a little (as it should) however it wobbles front to back also. Its not a huge amount of play but the clutch side doesn't do it.
