R-III-R Turbo
Mine is the biggest :)
Ireland
2472cc Supercharged Carpenter Rocket III Stroker
"THERE IS NO REPLACEMENT FOR DISPLACEMENT"
2.5L (2472cc) Stroker Package
Want the biggest motorcycle engine around and way more torque than the 2019+ Rocket 3?
Add ~10% BHP and ~12.5% Ft Lbs to your engine, throughout the entire RPM range.... no trade-offs!
Premium performance parts, all manufactured in the USA and EU.
Designed for use both in stock and in high performance big HP Rocket III engines.
The 2.5L Stroker package can be combined with all other performance enhancement products/packages, e.g. superchargers, exhausts, pistons, cams, etc for even more performance than they can deliver alone.
More torque at only 2000rpm than both the old Rocket III and the new Rocket 3 make at peak (3100rpm and 4000rpm+ respectively))!
135hp / 162 ft lbs (220Nm) @ the wheel (otherwise stock bike with 2.5L upgrade)
This means around 160hp / 190 ft lbs engine spec.
(The stock 2.3L Rocket III makes around 123hp / 144 ft lbs @ the wheel)
Includes:
• Billet Steel Stroker Crankshaft (with welded gears & balanced)
• Billet Steel H-Beam CP-Carrillo Conrods (3)
• Custom-Balanced Balancer Shaft
• High Performance Clutch Springs (5)
• CNC-milled 2500cc Side Panel Badges (to replace the OEM 2300cc ones)
• "STROKER" Decal (to replace OEM oil embellisher decal)
• TuneECU Map
Mail Order Package
€7,000
+ shipping
With receipt of stock crank & balancer shafts
For the mail order package send us your crankshaft and balancer shaft, and we will ship it back ready to bolt on along with the other components.
You will need to load the map via TuneECU.
Order now and also get a free T shirt :)
Due to the nature of engine modifications and high performance applications, R-III-R Turbo Performance Parts are sold without warranty of merchantability or fitness for purpose, express or implied. R-III-R Turbo Performance Parts shall not under any circumstances be liable for any special, incidental or consequential damages including but not limited to damages or loss of other property of equipment, loss of profits or revenue, cost of purchased or replaced goods, or claims of customer or the purchaser which may arise and/or result from the sales, installation or use of these parts.
Price current 02-Dec-25
And what abbot 6'th gear kit? Heard someone used to develop it.
That was a parallel development project to this one, but unfortunately never got past a fully functional 3D printed prototype due to the prohibitive cost of small volume gear manufacturing.
