Wierd buzzing from relay
Manual and electrical diagram is in my signature, and some other stuff that you may find useful.
btw, welcome and hang around and join in even after your problem is solved. Lots of good people here.
Wow, thanks. I have a mechanic friend coming over when he gets time, either today or later this week. He had asked if I had a service manual
For me it sounds like a bad ground. I could be wrong but it happened to me once....
I've unplugged and inspected all the plugs under the tank. Ditto with battery terminals. I want to check everything behind the engine but that looks like an awful lot of work. I have a mechanic friend coming over who knows way more about wiring than I do. I'm going to see what he says before I go any farther into her. Poor girl. I really hope it's as simple as a bad ground and I just haven't found it ye . Thanks
For a service manual and electrical diagrams go find any post by idk ( @idk ) and you will find a link to the good stuff in his signature.
bob
If you are posting from your phone, turn it sideways and you will get a couple of extra options. Edit is one of those.
Lol, thank . The best solutions are the simplest ones. Also, I've checked terminals and ever connection from battery to up under tank. There's some on the back down towards the starter but look like a lot of work to get to.
Hang in there, keep at it, and keep good records as you go, and that ride will be ever the more sweet.
Reactions: MIG
I wanted to thank everyone for their help and apologize for not updating. I work 70+ hours in the spring through fall which hasn't left much time dealing with this.
Got her figured out. After tearing her apart and scrutinizing every connector I could find, the mechanic friend I referenced earlier and I were convinced the ignition had fried. it was then we noticed some bare metal at a connector about 4" from the battery. That was the culprit. Pushed the wire back in and she roared to life. After all of this, removing the seat is all I would've needed to do to fix her.
However, there is a silver lining. I think I may have mentioned that I wanted to do a couple mods. One of them was replacing the air box with 3 k&n filters. I cant seem to reinstall the air box, so guess what my first mod will be? Having difficulty finding what I want but that's for a different thread.
Again, thanks to everyone. Appreciate everyone taking the time to help out a stranger
