Werkes - early observations and a couple of tips for installation
Journeyman
Old Fort, NC 28762 USA
2020 3R
Hi Journeyman,
I have been searching for the mounting instructions for CompWerks on my R3 GT. Thank you for posting this, especially the tip about the gasket. It looks like the gentleman who posted the video found it challenging to replace the gasket, I guess he had to take out the gasket out of the ring. You mentioned that you used "copper gasket seal on all connections". Where are these connections? I thought there just one connection for the pipe where you replaced the gasket from the ring? Also, any tip regarding the O2 sensor connection ? Do I connect the O2 sensor to the new CW pipe ? Thanks in advance
If you're careful you can work the stock gasket out of the steel ring- just use a small flathead and go little by little. As I said, I also used copper gasket seal (comes in a tube from auto supply store) on all connections to ensure the seal. You have the main connection going to the headers, the second can where it connects to the main muffler (it's a two piece unit), and then where you connect the O2 sensor- yes, you want to connect that. I no longer have my Werkes and have gone back to stock. I loved them for short runs, but on long distance rides the sound was just a wee bit too much. Anyway, they're great and you'll probably love them.
keramanmoto
Standard Bore
Rocket 3 GT
Thank you so much! I ride with a clan of HD guys with deafening pipes. Their sound comes loud through the full face helmet and ear-plugs. So, I may not even hear the CW. Let’s see.
Really appreciate your prompt reply. Safe riding
shyguy4407
Standard Bore
2022 221 Rocket 3 gt
I just did the same swap the other day, and what a massive difference. Nice throaty, mean sound. The popping on deceleration is definitely a lot louder, so I'm going to have to check for leaks (though I was pretty diligent when installing, so think it may just be something to get used to). I'll have to try to fab up something to allow me to record it when riding so I can post a video.
I definitely wish the new exhaust would have come with a new exhaust gasket. It's REALLY easy for the original one to come apart when removing the clamp from the old exhaust to the header. I ended up trekking to the Triumph dealer to get a couple of new gaskets (so I'd have an extra). At $11 for the gasket, it should have been included.
That third bolt was a challenge to find for sure, until I took off the other two and wiggled it around to see where else it was held up. That stock exhaust weighs a ton. The other thing I'd note is that if you have a GT (our have converted your R to forward controls), there is no need to remove the heel guard, since it's not in the way. The instructions also mention removing and saving the bushing from the center exhaust mount location (the one that's hard to find). You also need to do the same with the left side bushing, as the only bushings/bolts you'll reuse are the ones on the right side. I'd also recommend putting some black nail polish on the scratched part where the left side bushing mounts, so that it doesn't rust (it doesn't look like that existing bracket can be easily removed unless I'm missing something).
Other than having to search for that third bolt and get a new gasket, total install time would be pretty brief (i.e., on the order of 1/2 hour of actual work).
Overall, probably the most significant change I've made to the bike since I got it about a month ago. Killer sound (though the decel popping is a bit more annoying than pre-swap).
B
do you have any pictures of the right side of the bike with the new exhaust?
