tyre pressures.
Not according to Honda of Tulsa. They recommend 32 PSI front and back. Running 42 up front on Michelin Scorcher II 140/75R17 and 42 on back with a Exedra Max 240/55 R16. Just for general info the Scorcher II has the same tread pattern as the Exedra Max. Still have to get the exhaust hooked up, Change out fuel filter and change oil. Then a test ride. Been busy on the bike the last few days getting ready for new Exhaust system from Paul. Should be in soon. The heat outside has been unbearable. Very high heat and humid. Not so drunk and pissed tonight. Had a good day just getting things ready.
Well, we already know you can't trust those bastards!
I'm getting the same so wanted to mention you will need three of these...
Triumph EXHAUST PIPE SEALING RING Part # T2200326
I run my front 150/70 at 2.5bar and rear E-Max 2.9bar ( about 36 and 42) - But I am experimenting with a bit more next week (can't be bothered to play today - pool beckons).
When you run high speeds on open road the 34-36 pounds in front tire makes it have some vibration. 40 lbs smooth it right out
