tyre balance
you cant try it on a tire balancer it does not spin fast enough to do it have to be above 20 mph so you wont see it
i put my unbalanced wheel on and and with the bike on the center stand i put her in 5th gear and took it to 160 k/ph at 100 ks some vibration at 160 it was vibrating badly i could barley read the numbers on speedo and tach, after removing the wheel and hand balancing it chuck it back on and it smooth as at all speeds , may be if you have a center stand or jack it up you could try it and see if it vibrates , i don't think it would be as noticeable when riding on the road
i use goop in mine helps balancing and lasts the life of the tyre and prevents punctures !
