The 20355 kn TORS has alot more fuel and the O2 sensor unchecked. The 20355map2 is the stock map with open secondaries and fifth gear mapping in all gears.
You mean 5th gear's ignition table in all gears? I'm sure there's no objective reason to f**k with the timing. Why don't you try the stock 20355 map with O2 sensor checked and 100% secondaries everywhere? if the 2013 Roadsters are getting 163 ft. lbs. at the crank with that tune, there's no reason you shouldn't get the same with the same map.
