Tuneboy arrived
vic
.040 Over
Triumph R3 Touring
Now I gotta read the manual :?
Anybody got a custom feulmap for TOR/Bypass setup ??
Unfortenately the tuneboy comes with a map for staintune pipes only :?
Or a PC3 fuel trim map, (tuneboy is compatible)
I have the TORs, catbypass and undertank K&N and have been running with that Staintune map for a week now. I still get some decel popping but not as much as with the standard Triumph tune. The Staintune map is an excellent starting point for our setup. When I have more time I'll try tweaking a bit to rid of the decel popping, but it don't consider it a big problem since I had worse decel popping with the Triumph map.
You will notice an improvement right away after the Tuneboy update. Smoother power delivery and much snappier response even in the higher gears where there were no torque restrictions before. Why? That Staintune map is a dynotune map for optimum power across the entire range and the difference between optimum power and factory maps is quite distinct - it can be felt and heard.
ENJOY THE FRONT WHEEL REARIN' UP WITH NO EFFORT IN THE LOWER GEARS!!!
I asked Wayne for a tune for exactly that setup and he said to use the "20050stevedyno" tune which he sent me. I dont know how to attach it here, so pm me and Ill respond with it attached
I'm wondering if that "stevedyno" map is the same thing as the Staintune map that I have and downloaded from the Tuneboy site. I also asked Wayne if there was a better matched tune for my setup and he said the Staintune map is the best he has.
KC, you mind sending that "steve" map my way to see if there is any difference with the one on the tuneboy site? Me email is tah*AT*bpmsrat.com (replace *AT* with @) Thanks!
THx
Ok I'll start with the same tune for now.
Just to make sure as its the same can you send it to me too pls
ericho*AT*pandora.be
I am sure it is the same map.
Yup, it does look like the same map. Tune notes are the same and at first glance, the numbers are the same as well. Thanks KC for sending that file out.
Thx all,
I'll load it in there as soon as the tuneboy works :?
I got some linking, software problems going on write now,
As soon as its sorted I'll let you know how the bike runs with the stevedyno tune :wink:
Vic,
Be sure to go the the Tuneboy site and download the latest version of the tuneedit program. The one that comes on the CD has issues. At least mine did.
Tom
