Tune ECU confusion
hvacnr
McDonough, GA.
95 750 Magna, Rocket 3 2005, VTX 1800 2002
Hi All, First off I have a 2005 Standard with Power commander 3, factory air intake, and three into two pipes with out baffles. I have has hi idle and 2000~RPM off throttle issues. I changed the TPS with the new style, purchased the Tune ECU and thn cable for the android, installed and hooked up set the TPS and ISCA. information said it had map 20046. but then Tune ECU said their was an unknown map. What have I done wrong?
I have never heard of that map either, not saying it does not exist but I have not come across it, in saying that the 20050 (TORS) map had idle related issues and was replaced by the 20228 (TORS) map maybe the 20046 was the Std exhaust Map as they also released the 20227 map for the Std exhaust, if you like send me a conservation and include your email address I will send you a tweaked version of the 20228 (you wont need the PC3) which will liven it up or the 20227 if you want to keep the PC3or I can send both and you can experiment
Hans
Eventhough its a 05 I bet it was bilt in 04. It would not be the first one I have seen with a unrecognized map. I seen it at the hub in spikes bike.
Thanks, I would love to dump the PC3. The more electronics the more confused i get.
