Ok AndyH,
Please remember that I am trying to give help based on working on a 2006 normal aspirated Rocket 111. Just trying to support a fellow Captain.
There is no easy way to put this other than you will need to have a picture of each map Table: ie. all 3 F tables, all 3 L tables and the I1 table (this you can copy to I2 and I3). You may also need a picture of the Air/Fuel table.
My I trim table is all 0's and my 2nd Throttle is all 100.
NOTE: You may need to change the DISPLAY setting away from the graph to table (no tick for graph)
Once you have these pictures you can click on each table cell and input the value from the picture.
Also I would check each of the parameters - I am not sure if there is a comparison within Tuneboy - as I have not used this.
I Have changed my Rev. Limit to 6800, thermo fan to 96, speed adjust to 0 and Speed limit to 299 - Again I am not sure if these figures are the best for the TTS?
There is a good source of information about the TuneECU in the Tuning section.
Hope this helps
