Assuming you have Tuneboy - can you connect to read sensor data and do diagnostics stuff, fuel pump/fan/secondary throttle tests etc?
@late2ride got a TuneECU map from TTS I believe, but his bike has the newer model ECU than yours so map not compatible. Maybe he also got the older ECU map?
The TTS TuneBOY map for older ECUs is also stored here;
TTS Supercharger "Early" Rockets map (20222 Base)
