onesonwillie
Standard Bore
local dealer stated $3000 NZ dollars to fix and wind the bolt back in. im pulling the motor out myself have a look get to know her better and understand Why? seen a post on here about not putting enough loctite on the bolt. But i think after 150,000 ks shes done good. pull her down do both chains check out for wear, paint, polish restore back to original or better. my pic is my last Rocket both 2005srestoration about the same ks had the upgrade kit done. mechanics not able to get the upgrade kit now,you cant engage gears its only in 5th gear. i got home in 5th. it has no gear change because the bolt inside the case has come loose and is sitting on the sump. didnt make any sad noises just stopped changing gears..
