Thunderbike Tbars and cable brackets
REGULATOR
Turbocharged
Lincolnton GA
2005 RIII
ok before I resort to buying new plastic stuff from Triumph...or just using black zip ties etc...
does Flip or anyone else make those style clamps for the T bars?
I broke one of my plastic triumph clips...
have the bike all dissasembled in the garge while I wait for my new tires so I've moved the bars and a bunch of other stuff..and ended up breaking a cable bracket..
:shock: reg, you don't have to disassemble the whole bike just to replace the tire. You got the wrong shop manual. 8)
nope,
but have the bike on the lift and started tearing it apart,
lots of muck and gunk under the side panels and seat....
removed the battery ( put it on the tender) cleaned under there...
measuring to determine if I cna slip a fuel tank under the seat...
maybe relocate the battery to the spot the cat box used to be etc etc etc...
removed the tank, will attempt fuel gauge fix when I get some steady free time.... need to get my multi meter working....
removed teh gauges to see how those were set up.... like to do somethign with those eventually...
just knew I wouldn't be ridding for abit so started disassembly
Reg, Was in e-mail contact with flip 2 days ago - he told me that he can make the clips for the Thunderbike bars, but only to order, so there will probably be a bit of a delay. Best to order soon as, if you want them.
hmmm...
I migth have to contact him...would look much better then zip ties....
I migth wait and see, cause if I end up getting a corbin fairing It will be covered anyway (mostly)
