Teardrop Mirrors Won't Tighten
In that case I wouldn't be stufffing around. Send them the picture of the 2 stems showing they are different and tell them to send you a ***n set that will ***n fit.
i just put a set of triumph teardrop mirrors black on my r3t about 3 weeks ago no troubles . i have after market bars on my bike with no bar weights at the ends used the parts in the picture
I had the same problem with mine. The stem was longer than the stock mirrors so I ground them off to the same length as the stock mirrors and they tightened down just fine. No problems since. They are right and never move around
Ridefree
I've got them washered up but I might pull them off and grind them down.
Might have to grind down the bolts a bit too since they might hit home sooner?
The mirrors look good but I imagined them a little bigger.
I'm really picky about adjusting mirrors so I'm slowly getting them zeroed in.
Thanks for the help, guys.
I have them on mine and i installed them myself no loctite needed . sorry not sure what the problem is
