You will need to put something on the existing paint to make the pads adhere. Perhaps you could put a patch of clear lacquer on the area that the pads cover? that would give them something to stick to, use an aerosol can and mask off the area the pads cover???
Good luck, I put mine on a couple of days ago and didn't get them in exactly the right spot... I guess they will have to stay there, only I will notice
ps.... I have the gloss black... stuck fast so far.
Use 3m super weatherstrip adhesive( it comes in black) get all the old glue off first! then mark where you want it (useing masking tape around the outside of pad) good luck
That's strange ..... I have a matte black Roadster and they stick fine. Try heating them with a heat gun (just a little) and try again. Also 3m makes a adhesive promoter in which can be wiped on the sticky part and it will become sticky again.
