JackMcCornack
Are there any gas treatments that will work on this? I just went through installing a new fuel pump and having the injector nozzles cleaned, but it took a couple weeks and cost a couple hundred bucks, and I'd rather not do that again. Of course, last time it had been stored fifteen years and this time I'm only expecting eight months max, but still. It only has a smidge of fuel (a quart or two) but fuel injector systems stay full of fuel if you run them 'till they quit (unlike carbs, which pretty well suck to the bottom when they run out, and you can remove/drain the float bowls in situ). Is there anything I can add to the remaining fuel that will help keep my injector nozzles clean while they wait for my return?
