gR3yWolf
Turbocharged
I got my replacement Toyota Celica starter motor from RockAuto.com, Part # TYC 117774...brand new starter, $79.79 USD
I did use the solenoid that came with the new starter. You only need to cut the plunger shaft to the same length as the original plunger shaft. And if you compare the two contact discs side by side, you will see the new disc is larger in diameter as are the contact pads. This means more contact area which should allow more current flow. Also, the wire connection lugs may not be in the same orientation, but there is enough slack in the wire to connect up. I'll post pics of my swap out, if i can find them.
