starter clicks only when motor is hot
rogerp
Willis texas
2006 r3
when for a run about 80 miles stopped for drink switch bike on gauges sweep starter clicking .let it cool down then it started fine, did it again when i got home .new battery about 4 months ago will check relays and connections ! ,any help welcomed
Make sure that you have clean connections at both ends of the cables.Also have battery load tested I’ve seen new batteries go bad quickly.
I have been fighting this issue since my bike was a year old. During the last 6 years I have done all the up grades, starter, doubled up on the negative wire, Ken’s keyless system, battery always on a tender, clean tighten connections often, every upgrade made it better but still, every now and then a click and no start! Last year I replaced all the relays on the bike with new triumph OEM replacements! Been just over a year and not one dreaded click episode! Fingers crossed! I also purchased and extra starter relay to keep in my bag, just in case!
