There are splines up front and in the differential (it's called something else but I forget what it's called). Undo the nuts holding the shafts in place. Pull the caliper and the axle, roll the assembly out then the diff just pulls right out of the wheel. Clean it up and brush the lube on the splines. Easy peas you. I used a piece of cotton cord with a knot tied in it to line up the driveline when reinstalling. Once the splines are aligned pull the cord out and push her home.
i did front and back,removing the swing arm is quite a big job,i wont be doing it again but im glad i did there wasnt a lot of grease in there.im sure there is a manual to download somewhere on here..good luck with whatever you decide to do.
You only need to lubricate the rear spline on the drive shaft. This does require removing the bevel box/differential which is four bolts plus the left rear shock bolts. Loose on top and off on the bottom and you should be able to slide the bottom of the shock off the post. Clean and lube spline inside the axle tube (male) and the female spline on the bevel box. Don't be afraid to drop a tablespoon of moly in the spline cup before going back together with her. It's about a 10 minute job if the wheel is already off.
