Sounds just like a corporation protecting it's ass don't it?
Build in a 7% power reduction intentionally, then set the speedo to fake you into thinking you're haulin' ass when you aren't.
Hellfire,
Not a 7% power reduction, a 7% speed error. The speedo read 7% slower that actual speed over land.
Two solutions to the problem without screwing with your ecm (via Tuneboy to correct the speed).
(1) Some quick math will tell you approximately how fast you're going.
The error really doesn't make significant impact until you hit 50mph (error 3.5 mph)... going 80 mph the error is 5.6 mph). So if you going 50+ ride +5 on the speedo and you're certainly within the range that you're expecting.
(2) If you're passing everyone... Slow down. If everyone is passing you... Speed up.
The meaning of my
smart@ss answer... ride with the flow of traffic.
If there's no one else on the road, it doesn't matter.
Triumph retarded the timing in the stock version because they are protecting their collective arses. You can get all of the power back via Tuneboy, and apparently GiPro.
I, personally, tried the speedo calibration and realized that the odometer was more important to me because I gauge my refuel points by how far/how fast I'm traveling.
I don't trust the idiot light for the fuel.
So, I backed out the speedo correction via Tuneboy and I'm sticking to the 'quick math' solution proposed above.
