tribal
Moto Hobo Gypsy Vagabond
- Joined
- Apr 15, 2006
- Messages
- 889
- Ride
- 2005 Rocket III & 2015 Rocket III Roadster
This may a "no $hit" fix or repeat post but here goes:
Issue: Front brakes on 2005 R3 are barely working. Lever pulls in almost to the grip.
1st thing tried = replace brake fluid and bleed - helped a bit but not much
2nd thing = replace both sets of pads - helped a bit but not much
After 2+ years of inadequate braking I decided to attempt another fix before my upcoming
October winter escape run.
I went to put on new pads but they were fine and only slightly worn. Hmm, time for a new plan.
3rd thing = remove all pads and squeeze the front brake lever until all caliper pistons fully extend.
Ah ha, most do not!
4th thing = spray brake cleaner around pistons and gently free them without damaging them.
Once they are out, lube each one up with a good grease.
Push them in manually and repeat brake squeeze/lube until they all work as intended.
5th thing = lightly sand both sides of both rotors - also check for warping and float/free-play operation.
6th thing = replace both sets of pads and squeeze brake until both sides engage the rotor.
7th thing = Use a zip tie or rope to hold the brake lever fully engaged tightly to the grip.
Leave it overnight. This will compress the remaining air bubbles in the fluid and force them
out the calipers. Air in the lines is your enemy.
Remove the zip tie and (hopefully) enjoy your properly functioning front brakes.
This worked like magic and my brakes are now working almost as good as new...
If this doesn't work then the brake lines and/or calipers and/or rotors probably need replacing.
Ah ha, most do not!
