Single K&N vs 3 K&N filters
Whilst sorting out a new under bareclaw filter I've removed and replaced my plenum and under-tank plumbing so many times its now a piece of cake, :D. They say practice makes perfect. :p
Its all back to standard now and I don't miss the intake roar at all. :rolleyes:
I took your lead Battersea and used a K&N type panel filter in the standard plenum, Not ridden a bike with triple filters but I am happy with this setup.
A ball end allen key and a smear of rubber grease on the rubber joins and it all went together no problem.
Les tells me that his complete air intake system is still intack, the extra filter on the top of the plenum allows more air flow, I like it - its simple and semi standard:cool:
Okay guys I'm sure this question has been asked a thousand times, but aside from storage and a little weight savings at the end of the day in the real world how much of a difference is there in performance gains? That's all I'm interested in knowing. Don't need to know anything about tuners, fuel managers, and tunes. Thank you.
To answer the original question:
Just triples will give little if any performance gain.
You have to add good headers and pipe to get HP and that requires a tune.
OK you have 3 purchasable (as opposed to MAKING IT) options.
1) K&N replacement filter under the seat.
2) K&N under the tank attached to the rear of the inner plenum.
3) Triple K&N's direct to the Throttle Bodies.
1) I doubt there's any gain except you get to clean it rather than replace it when it's dirty.
2) Frees up the filter box for "gubbins". Very marginal improvement in potential air flow as you bypass the "snorkels" built into the seat.
3) Allows more air to flow at higher rpms. And allows you easier access to the throttle body adjustment screws.
1) Personally I cant see the benefit of this.
3) I've read actually flows worse at low rpms - and to get the benefit you really will need headers that let the beast breathe out better. And they can be as noisy as hell - mine (2009) is very loud at 2250-2750rpms with triples irrespective of load and secondary butterfly positions. VERY horrid slapping sound. And it whistles a bit too at times.
2) I ran with this until recently making my own modified plenum (similar to Battersea's but a little more "open"). No perceptible increase in noise over stock, breathes well enough with different headers such that one would be detained and locked away if caught. The monster will hit well over 200kph (5000rpm in 5th) with no effort at all fully dressed (screen and luggage) and 2 up. I used a Pipercross PK003F but others have used a K&N.
I would not fit triples again. I'd rather refit the plenum. Option 2 worked well for me.
K&N filter available from Flip.
http://www.flipmeisters.com/product...tank-air-filter-all-models-except-r3-touring/
Wayne MacDonald (Tuneboy) custom tuned and dynoed R3's with TOR's/cat bypass without and with triple pod filters. The results were: without - 157 ft lbs, 145 hp; with - 158 ft lbs, 151 hp. He also changed the ignition on the pod tune. These results are in the edit notes of those tunes.
  • 20050DynoFinalMap_TOR_CatBypass.dat
  • 20050DynoFinalMap_WithPods_And_IgnRetard.dat
Interesting, what difference did it make to the intake noise?
Good job Les .. bearclaw still fits by the look of it . How's the induction noise with your set-up ??
There is a little induction noise at certain revs when accelerating hard but when just cruising its fine, the exhaust is alot louder :)
Next time we hook up you can take it for a fang and see what you think.
