Battersea
Turbocharged
Hi Colin,
I just measured to distance between the posts 290mm, so I assume that in 10mm shorter than standard - 1" lower. Like I said - I do scrape the tyre but I have not wound up the stiffness at all, This is something I plan to play with....
Hope that helps
At 290mm they are 30mm shorter than standard (according to Hagon), this in theory should lower by around 38mm (1½") - but with a Ø1" bigger tyre you have a net 1" lower ride height, just as you say.
And yes it has helped - knowledge is power!
