barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
I have been riding in-line engined shaft drive bikes most of my life - I have never been without one. Hell I have had my current Guzzi since 1982. So I actually find it all normal.
Shaft drives with a single pivot (i.e. R3) will climb the pinion esp if they have thrust - UNTIL the forward inertia is enough to lift the front suspension. I find, generally, that shaft drivelines prefer to be set up for a corner and run through at a constant speed. Shafts with a second pivot can be very very neutral. But these can be expensive and a PITA to maintain.
The R3 ime will lift its head quite fast (so go wide) if accelerated out of bends too hard. Esp if you are near the peak of the torque curve. You can drift an R3 - into bends with some ease. I avoid doing so in the wet though. This ime helps more than throttling out - ON THE R3. And as has been mentioned I believe a lot of the R3 cornering characteristics has to do with the disparity in sizing of front-rear tyres.
This constant revs thing is allied to the rotating mass which generates a gyroscopic effect which CAN screw up axial rotations. Look up Gyroscopic precession.
Trail braking - works well. But with Classic footboards and the monstrously overpowered rear on R3's it's tricky. I am always very gentle with the R3 rear - maybe overly so - but it can lock up even with a CT on. Early Buells were infamous for having really poor rears - but were designed for trailbraking. And were bloody wonderful for powering out.
Also important to note (Rob) - Having decent suspension makes this more evident.
