Self cancelling Indicator relay
has any one fitted a self cancelling indicator relay to an 05 R3 was wondering if it will work given that the indicator switch is not momentary contact but a dedicated switch
yep I have a Kisan signalminder too - the relay will also do running lights [theres a dip switch on the relay so you can turn them off] and dip switches so you can have the turn signals set to 10/20/30 second flash -
signalMinder
be sure to order the correct one for the triumph [they changed since I got one] you also have to take out the springs from the indicators switch - I had a friend do mine as I'm no mechanic. You can also make the indicators do hazard warning.
or put the springs in I can't remember but its all in the instructions [with the springs]
I almost wish my Touring didn't have self-canceling turn signals. That means I can't just replace the relay when I put LED indicators on, have to add resistors and unnecessary load to trick the existing one into thinking I still have old school bulbs.
wow great website and it looks quality stuff
