has any one fitted a self cancelling indicator relay to an 05 R3 was wondering if it will work given that the indicator switch is not momentary contact but a dedicated switch
I've installed one. Comes with a couple of little foam pieces to insert into the switch to make it momentary contact, but I just took a dremel and ground off the little plastic piece that keeps the switch to one side or the other which turned it into a momentary contact switch. Either way should work but the foam pieces seemed sorta chicken$hit to me
I used to agree with that - until I forgot mine one day and a car pull straight out in front of me. I don't understand why they aren't fitted to all new bikes and, given the simplicity of the upgrade on most bikes, should be a retro-fit where possible.
