Rocket Roadster almost unleashed
WELCOME to ya, from WA State!
You have purchased the right motor and come to the right place!
TPS adjustment should be accurate but does not matter here.
If AT readings are high and it does not run properly set it back to 0 in Fuel- and AT-tables and enable AFR-target in this area.
AT is probably making wrong adjustments there.
But you can trust it at higher revs and loads.
Thanks I will give it a try.
At what percent and rpm is a good place to for the rocket?
That is hard to say. It will probably be the area up to about 20% tps.
But mainly where you got the too high AT-trims.
Even If your exhaust system is not leaking it can be reflux of O2 that causes AT to get wrong readings.
First have a look if she runs better there with 0 in PCV AFR taget und Fuel tables.
Thanks for your help good points I am off to it.
