Deamonkiller
Rat rod
Texas
R3 2022
FYI
When I was cleaning and doing maintenance on the bike, I found this wire that needed to be rerouted because it was a little too tight. It was an easy fix, but I had to disconnect the safety switch for the kickstand. When taking the two screws out, which was a little harder than normal I thought. I found a both screw holes had corrosion in it, or at least what I thought was corrosion, it could've been an excessive amount of Loctite but instead of it being blue like I see throughout the bike, it was red in color. I don't believe for this little bitty screw they would've used red Loctite. My suggestion is to look into it and get it cleaned up before it becomes a problem later. I've ordered the two screws because one of them is a little bit stripped from me and unscrewing it. I didn't have the tap to clean the hole so I used the old screw and screwed it in and out to get it cleaned and installed the two new screws.
FYI
thanks so much for sharing it along with photo. helps a lot
