@Neville Lush I believe you got this sorted by getting the existing one fixed according to a later post of @Mittzy.
From what I have seen NOT ONE online dealer parts listing appears to identify the correct ECU part numbers for Roadster models.
The key issue to determining suitability besides @HansO 's earlier post re Tunes, is the VIN that MUST have the correct VIN code for ABS inclusion models. A key point of confusion is that US/Canada VIN are different than UK and the rest of the world despite sharing 17 characters/digits. The US system uses this system and a check digit which is not used for UK/Rest of world VINs.
The letters "I", "O" and "Q" are never used in a VIN.
the link .pdf launches and may appear blank (zoom in to see text), which identifies VIN number codes for every Bloor onwards(?) Triumph model including the Rocket 3 codes below. The 4th, 5th and 6th digits on USA/Canada VINs and same codes on 6th, 7th and 8th digits on UK/rest of world like mine posted above for a 2010MY Australian sold Roadster ECU dated 12/2009 SMTTLC0235A432260
C00 = ROCKET III
C01 = ROCKET III CLASSIC
C02 - ROCKET III + ABS
C05 = ROCKET III TOURING
C06 = ROCKET III TOURING & ABS
Model year Alpha character in 10th alpha/digit for USA/Canada and the 11th for UK and rest of world. 2010 is A, 2011 B. 2012 C, etc to current 2018 J.
As @HansO advised the base tune is also different for 2010-2012 Roadsters and 2013 and later Roadsters. I am not aware of a further change to later Roadster base tunes but Hans should know.
I just bought a second hand 2016 Roadster ECU from the USA eBay for US$215 using the eBay 10% discount code PRONTO ;):D:thumbsup:
Link Removed
They had a good photo of the ECU part number and it does not show tune codes like earlier ECU's.
The VIN is USA/Canada: SMTC02L4XGJ730141
Part Number: T1290216
Tune: Not stated
Keihin codes are: Keihin 642D- 190G-0D0 1299300 7004-100952
Neville Lush's client's 2010 Roadster ECU below
Link Removed
Mittzi's 2010 Roadster ECU below
Link Removed
Mittzy's 'Unknown" new ECU (see in later post #24)
A few more examples:
Link Removed
OFF A 2007 ROCKET III CLASSIC. THE FACTORY PART NUMBER IS T1290102
Yet the unit also has the part number code 1290440 and Keihin code 129102. The VIN is incorrect for a 2008 model R3 SMTC01L457J298391 (10th character '7' is 2007 MY). Pre Roadster date codes are covered above.
OEM # T1299302 T1290102 ENGINE CONTROL MODULE
Triumph Rocket III 2300cc with only 13,332 known miles.
Link Removed
[ATTACH=full]54424[/ATTACH]
[B]Link Removed[/B]
THE OEM PART # IS T1290102
2006 Triumph Rocket III 3 CDI ECU ECM Engine Control Module T1290104
[B]Link Removed[/B]
An Aussie 2006 R3 version
[B]Link Removed[/B]
@HansO
I am wondering if putting this 2016 ECU in my 2010 MY Roadster and re-setting with TuneECU will allow me to use later Roadster base tunes releasing the secondaries in lower gears?
Confirmation of my new ECU VIN SMTC02L4XGJ730141
Enter your own USA/Canada only VIN and find out
SMTC02L4XGJ730141 - VIN Decoder Triumph
VIN Decoder
Decoding VIN numbers
Enter VIN number
Vin number analize
Entered VIN SMTC02L4XGJ730141
Corrected VIN SMTC02L4XGJ730141
Squish VIN SMTC02L4GJ
WMI SMT
VIS identifier N/A
VDS C02L4XGJ
Year identifier G
Serial number 730141
VIN type normal
Check digit valid
Check VIN number: SMTC02L4XGJ730141 and learn more about the history of this vehicle.
General Information
Make Triumph
Model Rocket III
Model year 2016
Body style Cruiser
Engine type 2.3L L3
Vehicle class Motorcycles
Vehicle type Motorcycle
Assembly plant Hinckley
Manufactured in England
Vehicle specification
Body type Cruiser
Displacement SI 2294
Displacement CID 140
Displacement Nominal 2.3
Engine type L3
Engine cylinders 3
Engine HorsePower 150
Engine KiloWatts 112
Standard equipment
No data
Optional equipment
No data
Further report details: Order report - VIN-Info
Basic Information
SMTC02L4XGJ730141
TRIUMPH ROCKET III
Bodystyle CRUISER Body CRUISER
Vehicle class MOTORCYCLES Vehicle_type 2-3 WHEELED MOTOR VEHICLE
Model year AVAILABLE Assembly plant HINCKLEY (ENGLAND)
Engine configuration AVAILABLE Engine type AVAILABLE
Cylinders AVAILABLE Displacement SI AVAILABLE
Displacement CID AVAILABLE Displacement nominal AVAILABLE
Horsepower AVAILABLE Kilowatts AVAILABLE
Vin SMTC02L4XGJ730141 Make TRIUMPH
Model ROCKET III Bodystyle CRUISER
Body CRUISER Vehicle class MOTORCYCLES
Vehicle_type 2-3 WHEELED MOTOR VEHICLE Model year AVAILABLE
Assembly plant HINCKLEY (ENGLAND) Engine configuration AVAILABLE
Engine type AVAILABLE Cylinders AVAILABLE
Displacement SI AVAILABLE Displacement CID AVAILABLE
Displacement nominal AVAILABLE Horsepower AVAILABLE
Kilowatts AVAILABLE
Make TRIUMPH
Model ROCKET III
Bodystyle CRUISER
Body CRUISER
Cylinders AVAILABLE
Kilowatts AVAILABLE
Full Report Status
Section Availability Count Period Sample
Archive images of the vehicle
20 photos 20 2017-08 - 2017-08 View Sample Report
Available 4.99 GBP
Vehicle History Report for a vehicle from the USA 3.9 GBP
Report with details from the USA that was specially designed as a reliable source of information, along with the history of vehicles coming from the US market.
A quick Google of T1290650 suggests it is for a Touring but need to clarify if ABS or non-ABS is limiting its application.
The application for a 2012 Roadster in the link below with only other year Tourings listed suggest the Roadster listing is an error. Weird but that T1290650 appears on Mittzy's 2010 Roadster's ECU as well but also has a different one on it too!
T1290650 Triumph Ecu, Xc, Base $929.93 - 2WheelPros
This part is utilized in 7 assemblies
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000662489.gif
2008 Triumph Rocket III Touring
ENGINE MANAGEMENT SYSTEM
This part is number 11 on this diagram
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000661653.gif
2009 Triumph Rocket III Touring
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000660786.gif
2010 Triumph Rocket III Touring
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000658731.gif
2011 Triumph Rocket III Roadster
This part is number 33 on this diagram
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000658887.gif
2011 Triumph Rocket III Touring
http://www.2wheelpros.com/oem-parts/images/diagramlg/0000655215.gif
2012 Triumph Rocket III Roadster
2012 Triumph Rocket III Touring
Also the Keihin 642D- 190G-0B0 1290650 2620-149645 serial numbers obviously include the Triumph T1290650 part number and was made in the UK whereas my later 2016 version was made in Thailand and its Keihin codes are:
Keihin 642D- 190G-ODO 1299300 7004-100952
Note the 'D' rather than 'B' and following the earlier observation mine also has a Triumph Part number match to Engine Management System. For Triumph | Triple Triumph Miami despite the Triumph Part number appearing separately as T1290216
The T1299300 part number is for Roadsters only.
33
ECM Base
Roadster Only
T1299300
$ 797.71
My bold in Red :(:banghead::banghead:
Aftermarket Products | Keihin-EU
Keihin does not have a direct sales channel for aftermarket products. Keihin has arranged with our distributors to offer support to individual customers for these products and purchases. Products and technical support for components that come as original equipment on vehicles is available from the product dealer or manufacturer. Unfortunately, Keihin is not able to respond directly to requests of this type for support.
Sudco International Corp.
2410 South Sequoia Drive
Compton, CA 90220
Phone: 310-637-8330
Toll free: 800-998-3529
Fax: 310-637-8331
Sudco Intl. Corp. - Sudco Catalog
(PWK, PJ, PE, FCR, FCRMX, CRS, PWM)
Bihr SAS
7, rue Robert Schuman
68870 Bartenheim, France
Phone: 0033-3-8970-3030
Fax: 0033-3-8970-3099
http://www.bihr.eu/
(FCR, FCRMX, PWK, CRS, PWM, PJ)
DG Performance Specialities
1371 N. Miller Street
Anaheim, CA 92806
USA
Phone: 714-577-7498
Toll free: 800-854-8052
FAX: 714-577-8651
(FCRMX, PWK, PJ, PE)
D&L Performance
901 Gaudette
St-Jean-Sur-Richelieu,
Quebec, Canada J3B 7S7
Phone: 450-359-7858
Phone: 888-689-6821
Fax: 450-359-7858
http://www.dlperform.com
(FCR, FCRMX, PWK, PWM, PJ)
Winners Circle
187 Steelcase Rd. West, Unit 19
Markham, Ontario
Canada L3R 2R9
Phone: 905-475-2552
Fax: 905-477-3270
(FCR, FCRMX, PWK)
Orma Divisione Motori
Via Posillipo 42
80123 Naples, Italy
Phone: 39-081-660-464
FAX: 39-081-662-073
(FCR, FCRMX, PWK, PJ, PE)
Exceed International
8830 Recho Rd. Suite F
San Diego, CA 92121
Phone: 858-453-3363
Fax: 858-453-2046 Tinh Anh
4 Bis/G Nguyen TrungNgan St. District 1
Ho Chi Minh City, Vietnam
Phone: 84-909-588-223
www.tinhanhshop.com
Thats cool - its not out of any of my bikes but is a NEW SPARE ECU.
