Thanks for all of the tips! But here is another question. Can you take a bike lift (similar to what you woud use to jack up a Harley) and insert under the engine to jack up the entire bike? I would but wood between the jack and the engine. I would also strap the bike so it couldnt's fall over.
Any one tried this before? Can you support the bike from the motor?
I raised the back of my bike with a motorcycle jack under the motor to install my rear shocks. I watched my Triumph mechanic change a front tire by raising the bike with a motorcycle jack under the motor. I've not seen my bike with both wheels off at the same time.
all these tips about removing 1 wheel at a time are very good,
but,
they don't help you when you need 2 tyres replaced and it's cheaper by over £70 to get them done on loose wheels rather than drive in drive out.
I got both replaced on loose wheels for £230, cheapest drive in drive out option woulda been £300 or maybe more :shock:
