tdragger
I'm not condoning this behavior at all I'm just stating facts
I've had people do this to me while in in a cage and on my bikes
The *****pulled in front of him and slowed down
HE SHOULD HAVE SLOWED DOWN
He didn't he hit him
In my state he is at fault period
Then he runs
After running over a bike or two
Really how did he expect it would end
He got off waaay lucky
Some of the people I know and ride with there would have been no video and no witnesses
But I've said too much
The SUV driver was at fault legally
Just as if some one would have cut you off to hit an exit ramp
A rear end collision is not the following drivers fault when there is clear and convincing evidence that the driver in front is illegally impeding the safe flow of traffic. You are incorrect in the assumption that it is always the driver in rear's fault. The motorcyclist is clearly with convincing evidence intentionally disrupting the safe flow of traffic.
Here is the section from the Virginia Traffic Code (similar code exists in all 50 states):
§ 46.2-877. Minimum speed limits.
No person shall drive a motor vehicle at such a slow speed as to impede the normal and reasonable movement of traffic except when reduced speed is necessary for safe operation or in compliance with law.
Whenever the Commissioner of Highways or local authorities within their respective jurisdictions determine on the basis of a traffic engineering and traffic investigation that slow speeds on any part of a highway consistently impede the normal and reasonable movement of traffic, the Commissioner or such local authority may determine and declare a minimum speed limit to be set forth on signs posted on such highway below which no person shall drive a vehicle except when necessary for safe operation or in compliance with law.
(Code 1950, § 46-212; 1950, p. 881; 1952, c. 666; 1954, c. 244; 1956, c. 364; 1958, c. 541, § 46.1-193; 1960, c. 153; 1962, c. 307; 1964, cc. 118, 408; 1966, c. 85; 1968, c. 641; 1972, cc. 89, 546, 553, 608; 1974, c. 528; 1977, c. 577; 1978, c. 605; 1980, c. 347; 1989, c. 727.)
And here is the Minnesota code:
169.15 IMPEDING TRAFFIC; INTERSECTION GRIDLOCK.
Subdivision 1.Impeding traffic; slow speed.
No person shall drive a motor vehicle at such a slow speed as to impede or block the normal and reasonable movement of traffic except when reduced speed is necessary for safe operation or in compliance with law or except when the vehicle is temporarily unable to maintain a greater speed due to a combination of the weight of the vehicle and the grade of the highway.
