They look very slick. Seeing that
@papanorm has one and recommends it is encouraging. I'm sure the spindle can be worked out. If I were just getting into changing my tires I might look into it. I currently have a cheap Harbor Freight stand and a Mojo Lever which works amazingly well. Less expensive, but you have to permanently mount the stand (unlike the Raboconda). The lever works great.
Before I discovered the MojoLever those that were mounting tires talked of having to cut through the bead with bolt cutters in order to remove the tire. Not necessary.
It's said that the Raboconda has a learning curve, but so did the Mojolever. I made a video using it, but have since perfected my technique to where it takes very little force to remove, or mount, a rear tire (fronts are easy). I guess I'm all set, but curious to see how the Raboconda works once you guys figure out the spindle issue. It does look to be a more "elegant" system.
This is a DIY install of the Exedra Max on the new 3R. It requires minor modifications to the forward most rear fender and, if doing it yourself, a tire stand and Mojo Lever - I'd say about a two beer rating for time/difficulty. The result, in my opinion, is a less expensive tire that provides...
www.r3owners.net
