R3 as a first Bike ?
Hi Karan.
A buddy of mine has a Royal Enfield (500cc), I rode it a little and found it very pleasing to ride...good balance and weight. That single cylinder is a good chugger and not too fast off the mark. The Bonneville with it's two cylinders could be a little scary stepping directly from the Enfield; a little more weight, torque and HP.
The Rocket 3 is miles from the Enfield. Not a little heavier but much heavier and you need to keep this in mind when coming to a full stop at traffic lights and when pulling out at an intersection. Not to mention the throttle control you need to learn with the R3. You don't want it to rip your arms off when pulling away.
I have about 300 miles on my R3 I am getting used to it. Am I confident?...a long way from being so but I am enjoying the learning experience.
I am 5' 11" and 180 lb. I am still working at controlling my bike but I have found the more I ride it the easier it becomes. But I still get tired.
Don't get me wrong...I am having so much fun.
I think that if you are a little shorter and less than 170 lb. This motorcycle would be much more of a handfull, especially without much recent bike experience.
My feeling would be for you to get something like a Triumph Thunderbird, tops. And then move up to the Rocket
All the best. Eric.
TIP...
The R3 handle far better with the correct tyre pressures..
There are a few variations between owners but only within a very small margin.
For some reason R3 pressures seem to leak away.. I think it is maybe the care taken by the tyre change fitters with the rim seal or its the valve to rim assy ..
Anyway I check my pressures every time I fill her up, about once a week using the bike every day for work and its often 2UP
I favour Front 38psi and Rear 41psi.
Hope this helps
I run 42psi front and rear but I also weigh half a tonne.
I know we are slowly getting off subject.
But the rear tire of my III was kind of flat shaped in the center. Maybe about 3 inches of rubber had this flat on it. At 7,000 miles.
This was unnerving when riding around bends, felt like the rear was wobbling and about to lose it.
Got myself a new tire and all is well back there...what a difference.
Eric.
Have always run 40psi front and 45psi back ... get fantastic mileage out of my Metzlers and i reckon it's the high tyre pressure ... Oh .. and i don't do burnouts, that helps.
I'll go to 45psi and see the difference at times my back tyres feels flat even at 42psi.
