jut got home from work let me start bout this morning did the same thing wouldnt do nothing as stated above got home and it started
now whats the diffence from 5 am to 830 pm if i get home early enough tommorrow gonna disconct battery and then reconnect maybe will reset ecu
Have you checked your battery connections? I have about 25K on my 08 and never had any problems like you are describing. I did have an engine light come on once and it went out. I had a dead battery once and just had to charge it. I live on the intercostal waterways in SC so lots of salt air and moisture. It may be wire connections, battery connection, switch connections. Clean everything off for corrosion and see if it helps.
i got it fixed it was the plug under the speedo when i reconnected everything i did not get that one plugged in all the way reckon was in a hurry to go ridin
