HeR3tic
Likely 020225 was the last file fetched and loaded as default?? The tune indicated at the top of the screen might have more descriptive details identifiedI have finally installed a tune boy and would appreciate some help please.
I have a Rocket III 06 Model with Jardines and stock airfilter at present...The screen at the top of Tune Boy tune edit screen lists File (020225 tune.dat)...std 020225 tune
That's a familiar tune: One that is "stock".The ECU indicates Tune (020145) Rocket III standard pipe and catalyst.
There's a table mod for the L1-3 tables, that Pig9r posted over a year ago, that has quelled the decel pop for my beast.The bike is popping on decel liks a bstard and I was hoping to eliminate or reduce this.
To start with, don't be impatient. Sometimes getting the ECU and Tuneboy to speak to each other can be aggravating. I've been using TB for two years and have not found it to be Plug~n~Play....I also am not sure of the process for downloading a different tune.
Be sure your USB is one of your "successful" ports. I find some work better than others more dependably. Shut down the TB software and connect the cable. Turn on the ignition key then start up the software. If you get a comms port error you're not connected
I recently had an issue with the TB package. TuneEdit worked like a charm but TB Diagnostics (the Dash Board screen) wouldn't connect. The ECU number must appear on the Dash Board. I tried various connection sequencing and still no go. I ended up downloading the very latest full TB package and was finally successful. I still don't know why I had the difficulties. I've used both aspect of the previous TB software version successfully in the past. It's a mystery and always a challenge.
Don't forget to write down the TB Key, somewhere you can find it.
Follow screen instructions and don't rush it; if not, a recovery from a failed download may be in your future. Don't be impatient. And put a charger on the battery.
I'm right there with ya. Incidentally, I write this a bit broader for others that haven't been as successful as yourself.Thanks (Computer idiot)![]()
